Hello,
I'm wondering what is a good way to safely switch on my compact portable battery powered device, which:
1. is powered by a 6S battery (so ~18V - 25.2V DC)
2. usually draws an average power of ~80-100W, so the current could be up to slightly above 5A
3. and when I measured the inrush current with a BM037 clamp meter, I measured around 90A(!) - (should I be very worried about this value?)
4. must be able to handle vibration and shocks (my current system seems to sometimes restart itself when knocked around a bit - I have a feeling it's due to the rocker switch not dealing with shocks well, but it's quite hard to replicate)
My current solution simply uses a high-inrush current rocker switch between the battery and a custom PCB (Bulgin 1350 high-inrush rocker switch, supposedly rated ~24Vdc/10A), and my PCB is protected by a 5x20mm F 15A fuse (which hasn't blown yet!).
I was thinking of changing my rocker switch to a push-button switch with a lower current rating (with some shock resistance rating) (are there smarter alternatives?), with maybe some sort of solid state relay - my idea being that no moving parts should mean higher robustness to shocks / vibration. However, I've also recently learnt of ICs such as "load switches" and "eFuses" on Texas Instrument's website which can perform the switching, along with current inrush limiting, and also remove the need for my fuse holder on the PCB, which sounds brilliant in theory. I also saw that a solid state relay that can handle my circuit is quite physically large and expensive (655-SSRDC-200D12 - $70!), so a cheaper load switch IC makes sense.
So I'm contemplating this option:
1. Use a simple push-button switch rated for >25Vdc ~1A, which will connect the battery voltage to a 5V LDO.
2. The output of this LDO is used to set the enable pin of a TI TPS27SA08 load switch, which then connects the battery voltage to my main circuit.
Is this idea functional? Am I missing anything? Are there smarter ways to do this?
Thank you!
