Wow, that's a lot of info already!
Let me be wayyyy more specific:
The espresso machine had two thermostats when I bought it (it's from 1985ish), so once the machine was clicked on, power would flow through the heater/boiler until it reached about 220f, then click off until it dropped below 190f or something like that. One of the big improvements to this machine is to add a digital temp probe and add a PID controller to keep the temp as consistent as possible. I've added a few other little things, but not a ton else electrically.
My house is 120v ac and built in around 1978. I'm pretty sure this outlet is very Daisy chained around the outside of our garage and connected to a fridge and a chest freezer.
I was hoping for something simple like adding (I think they're called) in rush capacitors, but apparently you can't do that with AC. I could possibly use a battery backup, but that sounds like a lot of trouble.
So what I'm gathering is I should run a dedicated circuit to a new circuit breaker? I'm really surprised to hear that the other guy's lights flash when their neighbor's air conditioning turns on, I'm not sure if that happens here or not.
