Hello everyone, I am trying to repair a Thermadyne Pakmaster 25 plasma cutter. When I try to crank up the current to cut thicker metals the plasma arc extinguishes, also at lower current settings the unit does not have the power it used to have. I am thinking the problem might be somewhere in the power Mosfet stages. I don't have a curve tracer or high voltage or high current probes to possibly poke around with my oscilloscope. I am kind of rusty in my electronics knowledge, I am an applied electrical engineer but don't work with much in electronics in my current job . I never could get the grasp of linear electronics theory. I have a TDS 420 oscilloscope and a MeterMan true RMS meter. I guess there is a high voltage capacitive discharge circuit portion that drives the cutting torch nozzle. Also I guess these pieces of equipment work off a really high peak inrush current to start a pilot arc that jumps to the piece of metal along with the use of compressed air. I would greatly appreciate some help. Here is an attached manual with a schematic
