Getting back to the OP's equipment:
The Antenna is a small loop designed for primarily Rx. It will probably survive a few milli watts of TX, More than that would burn something.
I built a small loop for over 100 watts and it is quite expensive. You need good components that can survive perhaps 10,000 Volts. They are very good antennas but require re tuning for even a few KHz change in freq.
The amplifier is intended to be used with a QRP transmitter Radio that puts out a few watts. perhaps 5 Watts. This is a common thing, used by lots of people who have QRP transmitters but sometimes want higher output. The quality of these amps varies greatly as does their spurious outputs. Some are quite good, others not so good.
About SSB vs AM transmitters.....you can run an amplifier at higher PEAK output on SSB because you do not have a constant AM carrier present. This is a common feature in normal HAM transceivers. This varies with the robustness of the final stage amplifier especially the output transistors.
It used to be that CB radio 2nd harmonic would interfere with the TV Band, Freq have changed and signal is also now digital (making the chance of any possible interference much less). Also most people use some version of cable rather than Over The Air signals.
A big danger of CB interference is in the 4th Harmonic which is in the Aeronautic Band 118.000 to 136.975 MHz. You can get into big trouble for this.
There are CBers who put out Tens of Thousands of Watts, More than most commercial AM stations. Some CBers even have 440 volt three phase electricity to their house for these illegal transmitters.
These folks usually only interfere with the use of the CB Band, since they can "STEP ON" or overwhelm lesser stations and the FCC does not seem to be interested.
