Hi all, I would a little bit of advice about a very basic best practice. When designing a trimmable voltage divider, I usually use the approach below.
My logic is that this is inherently safer, because even if you accidentally turn the pot to either end, a properly-chosen R1 protects the downstream circuit from an excess of current and/or voltage.
The simplest approach, however, would be to simply use a potentiometer, which also reduces the number of components needed. To me, this always feels very risky, because the output of the circuit is unknown until you apply a current to it… at which point it might well be too late :-)
Am I thinking about this problem the right way? I know that it's a small thing, but I'm curious about it. Thanks!
