Assuming that everything is connected correctly, it looks to me that the clock is not starting.
The only modifications I made is to use different Vref+ and Vref - (+2.5V and 0V), and I changed the RC values of the RC oscillator to 680pF and 3.3kOhm (I should get crica 200.53kHz)
I'm very sorry to be a bit condescending, but judging by your previous questions on this subject, I cannot help myself to not ask you:
Which part of the following sentence of the datasheet have you not understood:
ROSC (Pin 40 to Pin 39) should be 100 k.
You have used 3K3. Surely, there is a bit o discrepancy, don't you think?
Please try to implement the recommended schematic to verify that everything works correctly, then you'll have all the time you want to be creative.
Cheers,
Dan
