Author Topic: PSU YP1504PG  (Read 3071 times)
Offline DaxxinTopic starter
PSU YP1504PG
« on: April 13, 2017, 03:41:14 am »
Power supply LG M1921A vga+tv tuner monitor faulty , very similar schematic instead 12v i have 15v but actually measuring +49v and +17v instead +5v
shorted transformer? alredy check diodes mosfet and bridge all ok , optoisolator faulty can let the DC go till the output?
« Last Edit: April 13, 2017, 03:44:21 am by Daxxin »
Offline CJay
Re: PSU YP1504PG
« Reply #1 on: April 13, 2017, 07:04:57 am »
Check the capacitors on the output, if you're measuring the voltage with no load and they're faulty you will see some really odd voltages.
