Hey guys ... I received my DS1054Z and I've checked the built-in function generator (to compensate the probes) and each channel. What else should I check before I rip up the boxes? (ie. how can I verify everything is OK with the scope)
Don't rip up the boxes!
I strongly recommend leaving the scope turned on for a long period of time, like overnight. If the Options time out you can just unlock everything using the standard method.
If it is going to fail in any way you want it to fail within the _vendor's_ warranty period (which was 30 days for my purchase). This will make replacement a lot easier if there should be something wrong. It took three tries before I got a fully functional scope. First one had an intermittent glitch on CH4, that I finally proved by using the Mask Test function, leaving the scope on with no inputs to anything. Returned to TEquipment for a replacement. The replacement had the unusual "freeze bug" where, with certain settings, it would become completely unresponsive to controls (except the hard power switch of course.) This one had to go back to Rigol USA for a replacement. SO I'm now using the third unit, which has been fine in all respects. (To their credit, Rigol USA actually _asked_ me to send them the freezy unit, after they saw my videos on the bug. And they sent me a replacement before I returned mine, so I could test them both side-by-side for a weekend.) So I'm sorry, I am not one of the folks who will diss Rigol CS.
Moral of the story: Don't rip up the boxes!
