It's very likely to work, but you should verify this none the less. So just try it out.
What I would do:
First verify that both transformers work properly, (a bit depending on their origin).
Put the primaries in parallel. (that is always safe if it's for the rated voltage).
Keep an eye on the primary current of both transformers if you connect the secondaries. If the current increases, you have some extra losses.
Put some decent load on the transformers while keeping an eye on currents and temperature. A current clamp is best, but you can also add a shunt resistor to both transformers, as long as it's voltage drop is low, for example a 1 Ohm resistor in both of the primaries.
Also: You should give each of the transformers a separate primary fuse of a suitable value.
And please stop calling yourself stupid. Nobody is benefiting from that, you're just wasting the time of the people reading that.
