I'm fairly new to the electronic world. I've taken a college level digital electronics class, I've taken a basic high school electronics class. I'm trying to learn about circuits, how to repair them, how to build them, but it's going a bit slow. We have a baby now and I don't have as much time as I did before.
I have an old HP / Agilent / KeySight 16702B logic analyzer and I have an old Hitachi V-1065A 100 MHz bandwidth dual-channel oscilloscope. Today, in the mail, I received a 16760A timing and state analyzer module. I need to order some flying lead sets and probes for it. I think after spending a few hours googling, I'm even more confused than I was before.
I see for the logic analyzer module they make soft-touch probes, differential soft-touch probes, single-ended probes and differential probes. For my oscilloscope, I know they also make differential probes. For the life of me, I cannot figure out what the difference is between all of these.
I googled differential signal and found this on Wikipedia:
Differential signaling is a method for electrically transmitting information using two complementary signals. The technique sends the same electrical signal as a differential pair of signals, each in its own conductor. The pair of conductors can be wires (typically twisted together) or traces on a circuit board. The receiving circuit responds to the electrical difference between the two signals, rather than the difference between a single wire and ground. The opposite technique is called single-ended signaling. Differential pairs are usually found on printed circuit boards, in twisted-pair and ribbon cables, and in connectors.
But I'm still a little confused. Using two complementary signals....what exactly does that mean? Does that mean if we have an IC that uses differential signaling, on the PCB, one trace might send +5V, the other might send +3V, and the differential signal would be +8V? Or +5VDC and -3VDC and the signal would be +2VDC?
For the oscilloscope, I see words like passive and active. Not 100% sure what they mean either. From what I was reading, it might have something to do with impedance. If the component under test has a high impedance (greater than 1Mohm), I would want to use an active probe, if it's 1Mohm or under, a passive probe. I'm still a bit confused and any help from someone more knowledgable than me would be greatly appreciated.
Thank you!
