Found this thread after the LM741 ruined my evening again. Was trying to create a voltage ramp circuit to feed into diodes and transistors etc. to probe their behaviour across a linear voltage sweep. I found a circuit that used an opamp to amplify the first 2V of an RC ramp to give a more-or-less linear ramp.
Spend ages wondering why it wasn't working, long story short, I remembered that the LM741 only gets to about GND+1.3V. I tried dumb things like dropping the voltage on the feedback with diodes, but in the end gave up.
Obviously for this to work I need an opamp that will go less than a transistor/diode activation voltage above it's lower supply rail.
The guide above is great but it would be nice to have a basic list of "beginner op amps" for basic purposes.
So if you had to pick a basic (close to) rail to rail opamp for general tinkering what would it be?
EDIT: So I looked up the op amp used originally in the circuit I was working from, it was this:
http://www.ti.com/lit/ds/symlink/tl081.pdfFrom the circuit:
https://www.circuitlab.com/circuit/xw65e2/voltage-ramp/First he is running it at 0-23V which is beyond the amps specs of -18 +18V (or does it fall back to the differential voltage for + only)
Second I can see the common mode input voltage range is -12 to 15V but as that isn't relative to Vcc/-Vcc how do you know how low/high it's output will go?
The Peak output voltage is: ±13.5 but again, at what Vcc is that for? ±18V?
The other thing is that Circuit Lab did not simulate the 1.3V minimum voltage of the LM741, the circuit simulated perfectly when I exchanged that part.
Baffled.
