Hello,
I could totally wrong about this, so guys go easy on me if I am completely out in left field.
But, lately by experimenting with op amps I have come across some observations and I would like to know if what I observed is right. The configuration is where the inverting input
is connected with the typical rf and ra resistors and the non inverting
input is connected with the typical voltage divider formed by r1 and r2 resistors.
So, when dealing with traditional op amps in this type of configuration, can
one make the following statements:
When the voltage of the non-Inverting pin rises, the output will rise as well no matter what the inverting voltage is.
When the voltage of the non-Inverting pin lowers, the output will lower as well no matter what the inverting voltage is.
When the voltage of the Inverting pin rises, the output will lower no matter what the Non-Inverting voltage is.
When the voltage of the Inverting pin lowers, the output will rise no matter what the inverting voltage is.
HOWEVER:
When the voltage of the non-Inverting pin rises, the output can't lower no matter what the inverting voltage is.
When the voltage of the non-Inverting pin lowers, the output can't rise no matter what the inverting voltage is.
When the voltage of the Inverting pin rises, the output can't rise no matter what the Non-Inverting voltage is.
When the voltage of the Inverting pin lowers, the output can't lower no matter what the inverting voltage is.
Please note these statements are in reference to op amp configurations where we have an input voltage
ramp at one of the two op amp inputs while the other input is at a steady voltage.
Thanks for your feedback!
