Author Topic: reading diagram  (Read 4933 times)
Offline JblissTopic starter
reading diagram
« on: December 01, 2015, 09:12:54 am »
Hi Guys
silly question but can some show me how to wire this please
Online IanB
Re: reading diagram
« Reply #1 on: December 01, 2015, 09:15:27 am »
The diagram seems clear. What aspect of it is causing a problem?
Offline tautech
Re: reading diagram
« Reply #2 on: December 01, 2015, 09:18:31 am »
RV means variable resistor eg pot or preset etc.
This configuration is not uncommon with the wiper and one end on the pot "commoned".
Avid Rabid Hobbyist
Re: reading diagram
« Reply #3 on: December 01, 2015, 09:26:13 am »
so the pot is just is series and the common is connected to the centre pin ??
Offline tec5c
Re: reading diagram
« Reply #4 on: December 01, 2015, 09:27:57 am »
A potentiometer/variable resistor will have a minimum of 3 pins. Across two of them will be the maximum resistance value, while the third pin is used as a wiper (variable resistance pin). A quick check with a multimeter (or datasheet if you have access) will tell you which pin is the wiper. Once you know which pin is what, wiring it up should then be quite trivial.
Do you have a specific component you are trying to wire up? If so, please post a photo of it or link to a similar one.
Offline Gyro
Re: reading diagram
« Reply #5 on: December 01, 2015, 09:50:30 am »
Yes, basically. The center pin (wiper) is connected to one of the outer pins and to common (the schematic uses the chassis symbol - check that this is actually meant and is a safe thing to do).
Which outer pin you connect to depends on which direction you want to turn the pot to increase or decrease resistance.
Best Regards, Chris
Re: reading diagram
« Reply #6 on: December 01, 2015, 10:28:10 am »
So like this ??
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
Re: reading diagram
« Reply #7 on: December 01, 2015, 10:31:43 am »
So like this ??
how you've got it is shorting the power to the chassis. - not good.
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Re: reading diagram
« Reply #8 on: December 01, 2015, 10:38:14 am »
its a common 0v
Offline Delta
Re: reading diagram
« Reply #9 on: December 01, 2015, 10:48:18 am »
So like this ??
That will work great.  At ensuring zero output...
Re: reading diagram
« Reply #10 on: December 01, 2015, 10:55:06 am »
Can someone draw the correct way Please
Offline Deathwish
  • Country: wales
Re: reading diagram
« Reply #11 on: December 01, 2015, 11:04:21 am »
as asked per original diag
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline Joule Thief
Re: reading diagram
« Reply #12 on: December 01, 2015, 11:07:54 am »
Hi Guys
try
« Last Edit: December 01, 2015, 11:14:47 am by Joule Thief »
Perturb and observe.
Offline SL4P
  • There's more value if you figure it out yourself!
Re: reading diagram
« Reply #13 on: December 01, 2015, 11:12:28 am »
a potential problem as drawn...
at one end of travel, the high side will be 0R to chassis !
Don't ask a question if you aren't willing to listen to the answer.
Re: reading diagram
« Reply #14 on: December 01, 2015, 11:34:32 am »
Heres is the full Preamp Circuit
Offline SL4P
Re: reading diagram
« Reply #15 on: December 01, 2015, 11:36:50 am »
all good.
use JouleThief's wiring diagram.
Comment: using arbitrary arrows or symbols can suggest signal conditions that aren't actually present in the actual circuit.  The full schematic tells us what/how the VR is being used in the circuit, so how it is wired up becomes apparent.
« Last Edit: December 01, 2015, 11:40:36 am by SL4P »
Offline Delta
Re: reading diagram
« Reply #16 on: December 01, 2015, 11:43:21 am »
Please always post full schematics, instead of tiny snapshots.  Also, take a step back and look at what you've drawn.  Surely after 10secs of looking at your sketch you would see that that arrangement couldn't possibly do anything...
Re: reading diagram
« Reply #17 on: December 01, 2015, 12:34:22 pm »
Yeah sorry realised as soon as i posted it
Offline fleuroman
Re: reading diagram
« Reply #18 on: December 02, 2015, 12:54:10 pm »
RV1 is extending the voltage divider created by R1 and R4, a simple volume control, so it will work with either pin 1 or pin 3 of RV1 grounded, it might just work backwards to how you want it to work, the contacts/pins on RV1 should be numbered 1, 2 and 3, not 1, nothing and 1 as in the diagram
Offline tron9000
Re: reading diagram
« Reply #19 on: December 03, 2015, 08:38:23 am »
all good.
Hence why I assumed power on OP's last schematic.
