REALLY basic question on circuit analysis.
Posted by
zorthgo
on 20 Oct, 2012 19:42
This is kind of a simple question. But I can't put my finger on it...
I am studying for my electronics test next week, so I am going over stuff that we did in class. One of the examples, although very easy has gotten me stumped. On the attached file under case a and b, I need to find I
D, which is the current that will go through the load resistance. My problem is that I don't recognize the equation that gives me the 3mA for the ideal case and the 2.94mA for the actual diode case. At first I thought it was voltage/current division but for that I would need one of the two resistance on the numerator like:
I
D=V
th(R1/(R1+R2))
But the formula only has
I
D=V
th/(R1+R2)
It is missing resistance on top.
Can anyone tell me what formula that is? Is it a weird form of current/voltage division that I don't recognize?
Thanks!
#1 Reply
Posted by
zorthgo
on 20 Oct, 2012 19:46
Also... If it is just the basic ohms law, doesn't the diode have any resistance?
#2 Reply
Posted by
IanB
on 20 Oct, 2012 19:51
It's simple Ohm's law. The current ID through the diode is the current in the circuit, given by
ID = VTh / (RTh + RL)
The diode is "ideal" which means it passes current with no voltage drop. Therefore the diode behaves just like a piece of wire in this case.
In the second case, the diode is "real" and has an (assumed) voltage drop of 1.2 V. So the voltage driving current round the circuit is now reduced by the diode drop. So subtract 1.2 V from 60 V and repeat the above calculation.
#3 Reply
Posted by
zorthgo
on 20 Oct, 2012 20:21
Thanks IanB!
I have another question if you wouldn't mind. I am trying to solve a similar exercise but this time I have to find the resistance of R
L. I am positive that I need to use the formula I
D=I
se
Vf/.026. But the problem is that my number is coming out way too large. So large that my calculator can't even handle it. So, there must be something wrong. I would really appreciate if anyone could give a quick look at it.
#4 Reply
Posted by
IanB
on 20 Oct, 2012 20:32
Did you miss a "-1"? That is to say,
ID = IS(eVf/0.026 - 1)
#5 Reply
Posted by
IanB
on 20 Oct, 2012 20:35
(OK, I guess the "-1" might not really matter in many cases.)
#6 Reply
Posted by
alm
Vf represents the voltage across the diode. Why would this have to be equal to VTh in your bottom circuit? What about the voltage across the other components in that loop?
IanB: Assuming Vf is much larger than VT, the -1 term can be neglected. This is often done in introductory courses to simplify the math.
#7 Reply
Posted by
IanB
on 20 Oct, 2012 20:42
On looking at the problem statement, it doesn't seem to me that there is enough information to solve the problem. At least one further item seems to be needed.
We have Vs, R1 and R2 given, so the left half of the circuit is fully defined and can be made into a Thevenin equivalent.
On the right, we have IS given, which is a constant parameter of the diode. But it seems to me we need to know one other item, such as a voltage or current associated with the diode or RL? Without this information, I don't see how to calculate a value for RL?
#8 Reply
Posted by
zorthgo
on 20 Oct, 2012 20:44
Thanks alm, I see what you are saying!... but without knowing the current through R
th I can't calculate the voltage drop through it. Now I have a chicken or the egg problem.
#9 Reply
Posted by
zorthgo
on 20 Oct, 2012 20:52
Well, after realizing that V
f is not V
th I am completely stomped. Maybe it is a typo or something. I think I am going to move on and do another problem. This one seems to be a dud!
Thanks guys for the help though!
#10 Reply
Posted by
zorthgo
on 20 Oct, 2012 21:17
Question... I was looking at my notes, and now I am not sure about Vf. Is that the voltage drop across the diode (which is usually .7V), or the voltage going through the diode?
#11 Reply
Posted by
zorthgo
on 20 Oct, 2012 21:20
I think the .7 is called the Vcut in
#12 Reply
Posted by
alm
on 20 Oct, 2012 21:26
What do you mean with voltage going through the diode? You can have a voltage across a device, or a current through it.
I concur that the problem appears to have insufficient information. Even if you approximate the diode as a resistor or a constant voltage source, there is insufficient information to solve the equations in the Thevenin circuit (you only have one voltage, one resistance and one resistance/voltage to solve the current and three voltages). I wonder if something got mixed up with the IS, since 1.5 uA seems awfully high for a saturation current.
#13 Reply
Posted by
zorthgo
on 20 Oct, 2012 21:34
Because I am a little confused as to what Vf is. Because on one of the examples, for Shockley's equation ID=IseVf/.026, the Vf is actually the voltage drop across the diode. Which we were taught to just assume it is 0.7V. But I was thinking that the Vf was actually the voltage coming into the diode before the voltage saturation. Apparently I was wrong. Can you confirm that for Vf on that formula they are actually talking about the voltage saturation and not the voltage applied to the diode. Thanks!
#14 Reply
Posted by
zorthgo
on 20 Oct, 2012 21:36
You are absolutely right about the Is there is a correction that the teacher put out and the value is actually 25.69X10-15A.
#15 Reply
Posted by
alm
on 20 Oct, 2012 22:01
The diode has only two terminals, so the only voltage that it can sense is the potential difference between these two terminals. It has no memory of past voltages. This voltage determines its behavior (current) in the Schockley model. If solve the Schockley equation for Vf for reasonable currents (say 1uA to 1A), you'll get values fairly close to 0.7 V. If you would assume that the forward voltage is exactly 0.7 V, this would define the current through the diode and allow you to solve the problem, but I would expect this to be explicitly stated in the problem.
#16 Reply
Posted by
zorthgo
on 20 Oct, 2012 22:07
I would assume the teacher just forgot to state it. Because he has been using the .7 for all of his examples. So, would the current (ID) through the resistor be the same as that of the load resistance (Ith=ID=IL)? Because in circuits I, resistors in series had the same current running through them.
#17 Reply
Posted by
alm
on 20 Oct, 2012 22:17
Did they discuss Kirchoff's circuit laws? Because you should be able to derive this from Kirchoff's current law. This law applies to any circuits you'll encounter in introductory circuit analysis courses (exceptions include antennas).
#18 Reply
Posted by
IanB
on 20 Oct, 2012 22:26
Using the voltage across a diode to determine the current through it is a very unreliable procedure. As alm mentioned, a range of currents from microamps upwards will all produce a similar voltage drop. The usual way of solving the diode equation is to find the voltage drop given the current through it (and the junction temperature).
If we had a stated value of ID we would know the current through RL and could find the voltage drop across the diode, which would allow the problem to be solved in a meaningful way.
#19 Reply
Posted by
zorthgo
on 20 Oct, 2012 22:39
alm: We studied Kirchoff's law in Circuits I.
IanB: Shouldn't I be able to calculate ID by using the formula ID=(25.69x10-15A)e.7V/.026?
#20 Reply
Posted by
alm
on 20 Oct, 2012 22:52
Yes, assuming Vf = 0.7 V and applying Shockley's model would allow you to solve this circuit. The issue with this is that no EE would do this. The exponential relation between current and voltage means that any tiny variation in Vf or temperature will cause huge variations in ID. The very same property that allows you to assume it's approximately 0.6-0.7 V regardless of the current makes it useless to derive the current from.
You either assume it's approximately 0.7 V and that the current is purely determined by the other devices (assume Vf = 0.7 V, calculate the voltage across RTh and RL, derive current from Ohm's law) or use Shockley's diode equation and accept that it's a function of the current (and not constant). Both solutions would require information beyond what's given in this problem. I would probably pick some ID, like 1 mA, and go from there.
#21 Reply
Posted by
IanB
on 20 Oct, 2012 23:05
On paper, yes. In reality, no. Consider:
V
f = 0.68 V, I
D = 5.9 mA
V
f = 0.72 V, I
D = 27 mA
And that's assuming the value of 0.026 is accurate for the given diode (it isn't).
How reliable do you think your estimated current will be given such uncertainty?
#22 Reply
Posted by
zorthgo
on 21 Oct, 2012 00:43
Good point!... Not reliable at all.
#23 Reply
Posted by
M0BSW
on 21 Oct, 2012 11:46
This is interesting, as I'm fairly NEW to this side of the hobby I should read this Kirchoff's current law is there any other , laws I should be reading , I've done the ohms law so far.guess there's lots more "He Gulped ".
#24 Reply
Posted by
zorthgo
on 21 Oct, 2012 12:07
Well, Kirchoff's Current and Voltage Law, probably also nodal and mesh analysis. That is what we studied in Circuits I. Apparently it seems to be very useful!
