Author Topic: Why do I feel there's current to my left ear through earphone from tablet?  (Read 6826 times)
Offline Boris_yoTopic starter
  • Country: il
How is this pissible
 :-DD
(Reference might not make sense unless you watch 80s Brit-Coms)
Listen very carefully, I shall say this only once.
My misspelling amused you?
Offline G7PSK
  • It is hot until proved not.
If there is one lesson to be learned from this and the story on the thread it's never ever use headphones with any exposed metal in them, plastic all over is the order of the day. :scared:
Offline pickle9000
Plastic blades /cage on ungrounded fan can make a fair bit of static charge.
I would not trust the plastic to be insulated to 300V either, I would suggest not using headphones when the device is plugged into the charger, and get some external speakers instead. Used PC amplified speakers are cheap, or free if you look around a little. not going to be anything close to Hi Fi, but then again with low bitrate mp3..............
