Author Topic: Recommendations please – I2C or SPI controlled 2 channel 12 bit PWM driver  (Read 6094 times)
Offline Mr.BTopic starter
Hi all,
I don’t know if this is the appropriate place to post this…
I have recently been working with the NXP PCA9685, an I2C controlled 16 channel 12 bit PWM driver.
They are relatively cheap and easy to implement.
A design I am currently working on requires only 2 channels and the board needs to be fairly small. The PCA9685 is a bit of overkill with its 16 channels, and a bit physically large (TSSOP-28).
Can anyone recommend an I2C controlled 2 channel 12 bit (or more) PWM driver in a small SMD package?
I have hunted through Mouser search and cannot find anything suitable.
The device will be controlled by an ATmega328p-au, so the comms to the PWM chip can be either I2C or SPI.
Background to the design: ATmega328p-au, nRF24L01 radio, PWM driver, Power MOSFET x 2.
Forms the basis for a receiver module for dimmer control of 12vdc LED strip.
Transmitter/Controller yet to be designed.
Thanks in advance for any help.
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
Offline Kremmen
Any reason why you can't do it directly from the MCU? The 328 has 6 pwm channels built in.
Nothing sings like a kilovolt.
Dr W. Bishop
They are only 8 bit.
The first 20 or so steps of fade up look terrible.
Particularly if you are doing a slow fade - 0 to 100% over 10 seconds.
Thanks for your response anyway.
Offline PedroDaGr8
  • A sociable geek chemist
What about the TLC5973. I just saw it mentioned in another thread.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Thanks for that.
I will have a good look through the data sheet tonight.
Cheers
Offline Kjelt
In the same family there are also serial controlled devices (the TLC5973 is one wire protocol) like the TLC5970 which besides the 12 bit PWM has an additional 8 bit analog dimming.
Edit: The package of the TLC5970 does not meet your requirements  :(
« Last Edit: June 30, 2014, 08:35:03 am by Kjelt »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
"One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
Mode"
Whats wrong with timer/counter 2?
And you need a log function pwm to get linear brightness for your eyes.
Offline Kjelt
or a LUT a bit more costly but fast and precise.
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
What if you just slap in another micro that has two PWM channels on 16bit timer? I guess you can find a lot sot23-6 packaged micros from Microchip or Atmel to do that.
PCA9685 is an interesting part though, shame didn't stumble on it a while ago when I was looking for something like that, almost was going to do my own CPLD solution for that, luckily, the project didn't fly.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Great idea, keep rising the bill of material costs.  |O
Offline katzohki
    • My Blog
This is an app note from Micro, but the concept applies to any micro you would want to use. Might give you inspiration?
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en560120
Offline filip_cro
  • Country: hr
You can use 2 channel PWM on OCR1A and OCR1B.
Many thanks for all your input.
It looks to me like the TLC5973 will do the job nicely.
@katzohki
Thanks for the link. I will need to upskill myself on micros a bit more before I was to jump in to that.
However, the effort would be well worth it.
Thanks for that suggestion.
After a bit more research it appears that I should be able to implement it within the MCU.
http://arduino.cc/en/Tutorial/SecretsOfArduinoPWM
I haven't read the full article yet... Looks like Saturday will be spent working through this.
