Author Topic: Relay or transistor help  (Read 589 times)
Offline CramboneTopic starter
« on: February 09, 2024, 04:05:55 pm »
I’m looking for a device that will switch normal open to close when 8vdc 1mA is applied.
Drew
Offline Solder_Junkie
Re: Relay or transistor help
« Reply #1 on: February 09, 2024, 04:14:49 pm »
Drew
a 2N7000
SJ
Offline themadhippy
« Reply #2 on: February 09, 2024, 04:52:16 pm »
Does the switching side need to be  isolated from the control side ? whats sort of voltage and current are you switching with your 8v 1ma?
« Reply #3 on: February 09, 2024, 11:33:11 pm »
It’s creating a short to key an amplifier.
« Reply #4 on: February 10, 2024, 12:11:20 am »
A Kenwood transceiver? Try a 2N7000
SJ
« Reply #5 on: February 10, 2024, 01:37:21 am »
I should have put more info I’m tapping into a 8vdc TX source and want to use that 8 volts to close an isolated normally open contact will go to a rca jack on the rear of the transmitter. I’m thinking a relay of some sort but not exactly what type since I only see 100mA on the 8vdc.The amp is a simple short to ground for operate. I just don’t want to be bothered using a foot switch.
Not sure of one of these would work?
https://www.mouser.com/c/electromechanical/relays-contactors-solenoids/low-signal-relays-pcb/?coil%20current=44.4%20mA~~64.4%20mA&coil%20type=Non-Latching&coil%20voltage=9%20VDC&instock=y&rp=electromechanical%2Frelays-contactors-solenoids%2Flow-signal-relays-pcb%7C~Coil%20Current%7C~Coil%20Type
« Last Edit: February 10, 2024, 01:46:55 am by Crambone »
Offline themadhippy
« Reply #6 on: February 10, 2024, 01:57:14 am »
Hows about a 9v jobbie like https://www.farnell.com/datasheets/8046.pdf seems to  kick in at 7.2V and only wants 16.7mA
Offline David Hess
  • DavidH
« Reply #7 on: February 12, 2024, 08:49:13 am »
I would use an optocoupler like a 4N32/4N33 or TLP4597.
