I got this japanese electronic, I have many japanese electronics running on 120v just dandy normally.
This 1 in particular, seemed to progressively get worse the longer it was plugged in.
1 terrible flaw with this specific piece is there is no fuse.
also, the machine required a ground, but there are not ground slots in japan normally.
I know definitely this piece was used without grounding it ever before it got to the states. I received it with a little adaptor to bypass ground from the previous owner.
It had a problem when it was purchased, but it got worse and worse.
It has a panel of buttons with a display, and the buttons trigger randomly and sporadically, LEDs seem to go out and come on regardless of button presses...
What would happen if something was run for nearly 20+ years without it grounded?
& Then was grounded while powered after all that?
Thanks ahead of time!
