Only reason those crystals are around is because they had 2 major uses, TV IF oscillators and filters since 1954, and then, because they were a cheap and available item, they were then used in DTMF tone generators, developed by 1960, as a low cost precision reference oscillator for tone generation. Thus they were both a very cheap, and very precise, quartz crystal oscillator, and thus were used in the first microprocessors as a clock generator, because they were cheap, worked well with a single transistor oscillator, could be divided down easily with a 7474 to give you a roughly 1MHz clock with 50% duty cycle, and ran the processor at a decent speed.
That the clock was so close to TV line rates also helped with video generation, but the leading contributor to use was that you could get them very cheaply, and they were widely available, unlike any other crystal, and were a no set up device unlike a LC oscillator or any other form of oscillator. you have the design, apply power and, within the limits of your test equipment, it would work, and you could test it just using a regular TV set.
