Anyway, I have viewed the BD139\140 datasheet and they didn't mention anything about the bandwidth\transition frequency? do you have an idea why? the original ones are 100MHZ
Look at the Op Amps driving them. Their bandwidth is positively slugged by the 2n2 capacitors in the feedback loop (X
c at 100 MHz less than 1 ohm), the Op Amps have a GBW of 3 MHz and it's driving a TIP36C with an F
t of 3 MHz, the base of those transistors will never see anything like 100 MHz. So a high F
t for that transistor is actually a potential liability, inviting instability and self-oscillation.
The BD139/BD140 will do fine here. If anything they are over-specified on the power handling side of things. From memory that transistor only has to sink 30mA (I'm too lazy to dig the schematics out and check) sourced by an LM317 wired as a constant current source. I lied, I'm not too lazy - 39 mA.
