Author Topic: Rigol DS1052E 50Mhz or Siglent SDS1072CML 70Mhz [EU]?  (Read 2735 times)
Offline permababyTopic starter
« on: December 16, 2014, 06:05:52 pm »
I'm looking into buying a hobbyist scope and I was surprised to learn that the Rigol DS1052E Dave Certified scope sells for only €239 ex VAT [1]. The Siglent SDS1072CML sells for €253 ex VAT [2].
I've compared the datasheets of both scopes [3][4] and there doesn't seem to be much between them. That shouldn't be a surprise since both have been designed and manufactured by the same company.
They both have a 1GSa/s sampling rate for 1 channel, 500MSa/s for 2 channels (Dave's #1 most important DSO requirement, see EEV #13). The Rigol has 1Mpts deep memory, the Siglent has 2Mpts (Dave's #2 most important DSO requirement). Is the 2Mpts worth the extra money?
[1] Rigol EU website: http://www.rigol.eu/products/digital-oscilloscopes/ds1000e/ds1052e/
[2] Siglent EU website: http://www.siglent.eu/oscilloscopes/sds-1000cml-series.html
[3] Rigol DS1000E series datasheet: http://micromir.ucoz.ru/Oscil/Rigol/DS1000E.pdf
[4] Siglent SDS1000CML series datasheet: http://www.foldertrade.hu/download/DataSheet_SDS1000CML_datasheet_en.pdf
Offline dworki
  • Country: cz
Re: Rigol DS1052E 50Mhz or Siglent SDS1072CML 70Mhz [EU]?
« Reply #1 on: December 16, 2014, 07:13:15 pm »
From the two options I would choose DS1054Z :-) Look it up on this forum. It's de facto replacement of DS1052E with four channels and equally "extendable" to 100MHz.
Offline tautech
« Reply #2 on: December 16, 2014, 08:04:13 pm »
Siglent SDS1072CML is a mature product like the DS1052E, both well liked but the Siglent has a 7" screen. This is the way many DSO's are going, meaning when the Menus are on screen you still have a 5" display.
The newer DS1054Z mentioned had a problem that required a firmware update and this created problems of its own. One could say this product is not yet mature.
It is a 4 Ch unit with all 4 shared by one 1 G ADC. This lowers the sampling rate with all channels on to 250 Msa/s.
Avid Rabid Hobbyist
