I've just bought my first oscilloscope, and after some initial tests I would like to ask you some question.
I've tested build-in generator, and I noticed that when I use BNC cables, after some frequency, amplitude starts dropping a bit (no matter if I use 50ohm terminator or not), as you can see on attached images when I use BNC cables, at 25MHz amplitude drops around 5-7%.
I'm aware of transmission line theory, but thought that with 1m cable at 25MHz with 50 Ohm termination there shouldn't be any drops.
I would like to ask you if it is normal or I need to buy better cables/connectors.
BNC cable, connector and terminator are from Amphenol, so there are not the cheapest.
