This is mostly justification for getting the equipment and learning it. Once I have it I can use it for more advanced projects which was literally the only reason I was researching the 2072a for a while.
> You could even use audio trafo, ones used for 100V installations, and put it in reverse, watch secondary low voltage for distortion, and then just use good TRMS multimeter (would need to have 100kHz bandwidth) to measure exactly output and input of amplifier... And if you use good AC TRMS voltmeter, it would be very accurate...
I had actually considered just getting a DI rated for speaker level input and feeding it into one of my audio interfaces.
> Also 100x passive probe would allow you to check one and then other side of bridge amps to see if they clip symmetrically...
> You couldn't measure across the speaker with it, of course, but one side and then other ...
One thing I was also curious about was testing to see if phase was 100% in line across all channels. Obviously it should be and it wouldn't be the kind of phase plot you get with SMAART but it would be enough to see if the amp/receiver had any weird processing going on.
> And I know why you're asking, you were very polite saying creatively written specs... they simply lie with the specs
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/xfacepalm.gif.pagespeed.ic.EBDwh1hCfo.png)
I am not too concerned about my professional level equipment since most of it is tested to a real standard that you can check, but the consumer stuff I am integrating with... The sad thing with some companies is the engineers put in a bunch of work in getting accurate measurements and then the marketing department gets their most creative people involved.
I have also heard of some amplifiers that actually have the positive / negative output circuitry balanced between the positive and negative to get away with lower rated components so I will be sure to verify that isn't the case too. If it is then either a transformer or differential probes are the only option for that amp.
