Hi Guys,
I'm going to try make some sallen key filters for a university project with the hopes of making an EQ unit. I'm studying music technology and am a complete beginner with electronics so I have a few (stupid) questions.
1) Has anyone got any decent sources about the construction of/working with Sallen key filters that they would recommend?
2) I have chosen some component values in the link below to get a desired cutoff and Q. In your experience will these values work or should I aim for different values?
https://docs.google.com/spreadsheets/d/1lN3tLxwtOUL513ik1I3b4O2mQuzJMyJDHgwNR45Xji4/edit?usp=sharing3) If I want to add a control for the frequency is that as simple as using a potentiometer for the resistors in the circuit?
4) When I have been looking at components I have seen things like 'power rating' (on pots) and "voltage rating" (on capacitors). What values should I be looking at for those in an audio circuit and how do I pick the correct one.
Thank you to anyone who reads this and a big thank you to anyone who replies
C
