Author Topic: Scary Mains Power Stuff....  (Read 11633 times)
Offline vk6zgo
Re: Scary Mains Power Stuff....
« Reply #25 on: August 19, 2014, 12:16:59 pm »
@Simon the standard of education is a real problem at University level because of dumb stuff like this, unfortunately we still have to teach them a lot of what you and I consider common sense... using a hammer to put in a screw is very, very common...
That said perhaps it is because not everyone is technically minded. I was always interested in what my dad was doing as a kid, and wasn't one hanging out on the streets messing about, so perhaps that makes me the strange one?
Either way these LightwaveRF units look relatively cheap... £10 a plug and can be controlled using a 433MHz transmitter which are super cheap.
Ideally there would be a UK PowerSwitch Tail with some kind of certification, rather than a disclaimer at the bottom stating "Our liability is limited to the purchase price of this product only. By using this product you agree that PowerSwitchTail.com, LLC can not be held liable for any damages or injuries resulting from use, misuse, or repair."
Disclaimers aren't valid in the UK...
I shudder for the future of Art,if Artists are no longer interested in practical matters.
Artists were in the forefront of development of many of the processes which are the foundation of modern Industrial practice.
For instance,the moulding of large metal objects was first done by sculptors.
Paint pigments were part of Art technology for many years prior to their Industrial use.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #26 on: August 19, 2014, 12:26:26 pm »
I think the bottom line is that if an artist is going to be working in other fields as well they need to be knowledgeable in those fields, being an artist is no cop out. You either know how to do it yourself or you get someone in to do the techy bits for you under your artistic direction. It's like expecting an architect to physically build the house as well as design it.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #27 on: August 19, 2014, 12:42:56 pm »
Day Job: Mostly LEDs
Offline con-f-use
  • Country: at
« Reply #28 on: August 19, 2014, 12:44:05 pm »
Why don't you guys design a simple relay board yourself and have it manufactured?
Offline Simon
  • Global Moderator
« Reply #29 on: August 19, 2014, 01:11:56 pm »
because in this stupid country we have to worry more about being sued in case someone does something stupid and hurts themselves and then blames you although it was down to their own stupidity......
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #30 on: August 19, 2014, 01:40:35 pm »
String these words together in a paragraph for a requirements doc...
Isolation
Self-Contained
Standards compliant
Double-insulated construction, or Ground mandatory before operation.
Continuous Earth path to connected downstream devices
Mains 90-250VAC  50/60Hz rated
Safety enclosure (shatterproof / Tamperproof / IP-rated for splash/ingress)
RCD/ELCB/Safety Switch included within device
optically isolated control (specify the interfaces expected)
PWM control optional e.g. Triac/SSR vs Relays
Doube-pole option if relays used.
RFI/EMI compliant
Feedback of output state
Visible indication of output state (LED/neon etc)
Fail-Safe functionality - no input = default OFF
Portable as needed
Re-usable for future projects.
Don't ask a question if you aren't willing to listen to the answer.
Offline Simon
  • Global Moderator
« Reply #31 on: August 19, 2014, 01:59:05 pm »
your point being ?
Offline kingofkya
« Reply #32 on: August 22, 2014, 10:53:11 pm »
Hackaday had a a good post about a really simple way to control the mains. One of thous modules that turn off went the sun comes up plus a led:)
http://hackaday.io/project/46/log/2548
http://hackaday.io/project/1047-Opto-isolated-AC-Mains-Switch
Also you may want to show then alliexpress and ws2811 they might have more fun with thous and there 5-12v
« Last Edit: August 22, 2014, 10:55:22 pm by kingofkya »
Offline rolycat
« Reply #33 on: August 23, 2014, 12:35:53 am »
Why not use one of those 'energy saving' mains socket strips with USB leads?
For example:
http://www.amazon.co.uk/Ecotek-Standby-Saver-6-Way-Socket/dp/B0017PTD3M
or
http://www.ebay.co.uk/itm/141314890586
This is a US version:
http://www.ecostrip.com/
These use the USB power to energise a relay which switches the mains sockets. Turning off your PC also turns off the peripherals.
They aren't that great for their intended purpose since many PC USB ports remain powered from the standby supply when the PC is shut down, but I imagine a suitably buffered 5V signal from an Arduino or whatever would work perfectly well.
« Reply #34 on: August 23, 2014, 08:07:18 am »
Rated 18 Not for sale to persons under the age of 18. By placing an order for this product, you declare that you are 18 years of age or over. This item must be used responsibly and appropriately.
WTF? :-//
« Reply #35 on: August 23, 2014, 08:20:02 am »
Not allowed to use a credit card til over 18 so if you are using parents card they are covered if you kill yourself.
Offline rolycat
« Reply #36 on: August 23, 2014, 02:26:56 pm »
WTF? :-//
That is weird - that warning is usually attached to bladed tools, although it's hard to imagine a teen gangster terrifying the populace with one of these:
http://www.amazon.co.uk/Faithfull-1099-Piercing-Saw/dp/B000297TEY/
« Reply #37 on: August 23, 2014, 02:40:04 pm »
Probably boilerplate attached to any mains operated equipment. Your child could plug it in and shock themselves, so if the adult ordered it the responsibility and liability falls on them instead, as they are deemed to be the one in control.
Offline rolycat
« Reply #38 on: August 23, 2014, 02:59:22 pm »
Nope, you can buy mains powered equipment in the UK at any age. None of the other mains sockets I looked at on Amazon UK have that message, although a lot of bladed tools do.
