Hey guys I took a truth table and made 7 k-maps from it for all of my 7 outputs using only 4 inputs. Next i identified logic gates that appeared in multiple k-map SOP forms. Once that was done i started to make the schematic in diamond lattice.
My question is how i can i tie one AND gates output to multiple outputs..says 1,2,3 for example? -the 1,2,3 would correspond to lights on a 7-segments display.
I was not sure how to do this as connecting the wires directly is not working...i tried this bus tap which allowed me to connect the wire to output gives me weird output in my spreadsheet, so i know that is probably wrong.
Thanks for any help
