Well, I bought a new scope in 1986, and it came with some Probe Master probes, I think. They lasted about 2 WEEKS. I got some cast-off Tektronix probes from work, and they are STILL working! Ummm, that's over 800 times longer life. (I did have the hair-thin wire in one of them break, but I was able to fix it.)
Just get a generic 10X probe, and it should have enough compensation adjustment range to cover most scope's input attenuator. If you want to be sure, look up the input capacitance of your specific scope and check that the intended probes cover that. All scopes should have a 1 Meg Ohm input impedance.
Jon
