Author Topic: dvd drive sata preserve  (Read 2187 times)
Offline Ranayna
Re: dvd drive sata preserve
« Reply #25 on: May 06, 2022, 12:18:17 pm »
I never had luck opening a drive sled with a paperclip. The clips are too soft and they bend before you can exert enough force to overcome the latch.
To push open a drive sled, you really need quite a bit of force.
Luckily, i still have an original opening pin that was included with a drive many years ago. That has at least double the diameter of a paperclip, it actually barely fits the hole. It flexes a bit, but does not bend.
Offline tiago1986Topic starter
« Reply #26 on: May 06, 2022, 12:33:47 pm »
i dont know how to identify a faulty belt but i will post a picture of the belt i took from my asus dvd drive obs. the tray does not open or opens 80 or 90% it only opened when I put the clip several times, drive is new
Offline Ian.M
« Reply #27 on: May 06, 2022, 12:46:32 pm »
You can't tell a bad belt just by looking at it.  With experience, you can stretch it  and asses the condition of the rubber.  e.g. if it doesn't immediately return to the original size when released or shows any signs of surface cracking or crumbling or looks uneven when stretched, its bad.
« Reply #28 on: May 06, 2022, 01:13:29 pm »
After I removed the rubber the drive slides normally through the drive but with rubber the drive does not open tray or the tray opens 90%
I still don't know whether or not to buy another rubber
« Last Edit: May 06, 2022, 01:15:14 pm by tiago1986 »
Online tunk
  • Country: no
« Reply #29 on: May 06, 2022, 03:05:59 pm »
Your country flag says Belgium, and I assume they have pretty good
consumer protection laws. Take it back to the seller and ask for a
refund or a new drive.
Offline MK14
« Reply #30 on: May 06, 2022, 03:52:21 pm »
I suspect they might be from Brazil.  They seem to have been banned for spamming identical topics/questions.
