Hi Guys and Gal's..(Don't know if there any here ) Just being PC. As you can see I have a Sencore LC102 & a LC103 Cap Checker. And I just picked up a Sencore LC103. I was told that the LC103 had a Problem. I did get a good price due to that. It looks brand new and looks like it has never been opened. I have it open now and just blew the dust of the IC Top side. It's very clean. I have a full complement of test gear here.
So I wanted to make sure the LC103 is working and or locate the problem. So Here's the Problem on the LC103. I can't find one??? The only thing that I don't understand between the 102 and the 103 Is the Cap Leakage test.
They both show that the cap is good but the way they both display it has got me wondering. I will post a pick I found on line of the LC103 in the Cap Leak Check mode. Notice that The Lower bar graph is full on to the right, And the Leakage in Ua is "0"?? But the upper right shows resistance in Ohms and it says "Good"
The LC102 display shows in Ua's and says "Good". It does not display in Ohms.
I'm beginning to feel that nothing is wrong with the LC103. It would be great it those of you agree with me here on this reading. I Have checked a number of caps with the LC 103 and have yet to see an indication Of Leakage in Ua's.
I just happened to pop in here after doing a search on googel and ran into a thread fro 2019 about repair problems with the LC 102. So.. Gald to be here with the experts and Thankyou in Advance.
I served in Vietnam thru 66-77 and when I had a Problem I always went to the Old school Sergeants to set me straight. I hope someone here can help out.
