Author Topic: Small toroid mechanical fixturing  (Read 531 times)
Offline matthuszaghTopic starter
« on: November 28, 2022, 06:26:29 pm »
I'm building a PCB circuit that requires a custom-wound toroid for use as a 3-winding transformer. The toroid will be pretty small: OD=9.5mm, ID=4.75mm (https://www.mouser.com/ProductDetail/Fair-Rite/5961000201?qs=Ca1fAiqt1aqSBOA35FqYWg%3D%3D&countryCode=US&currencyCode=USD). I'd prefer that the toroid not be mechanically supported by the transformer windings. Suggestions for how to support this mechanically? An enclosing case, especially one that does not allow water and IPA to enter, would be nice but not necessary. If using the windings for support is the typical solution, that would be useful to hear, along with any suggestions for how to make that robust (e.g., keeping the leads short).
Offline fourfathom
Re: Small toroid mechanical fixturing
« Reply #1 on: November 28, 2022, 06:57:15 pm »
A [machine screw / insulating washers / nut] through a hole in the PCB?  Zip-ties through holes in the PCB?  Glue?
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
The following users thanked this post: matthuszagh
Online TimFox
« Reply #2 on: November 28, 2022, 07:17:15 pm »
One thing to avoid is a conductive path that goes around the toroid (from the bottom, through the hole, around the top, and back to the bottom).
That forms a "shorted turn" that will degrade the transformer.
A screw through the hole, with no "roof" around the toroid, is OK.
Offline Benta
« Reply #3 on: November 28, 2022, 10:25:28 pm »
A toroid that small would typically be mounted with a blob of thermal glue.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: November 29, 2022, 01:46:19 am »
Agreed, glue, hot-melt, E6000, silicone, etc. would all be fine, to varying degrees of permanentness.
Seven Transistor Labs, LLC
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #5 on: November 29, 2022, 04:19:52 am »
I've seen them in HP/Tek gear fixed in place with two cableties wrapped around each side of the toroid and through 4 holes (two per cabletie, one inside the toroid and one outside)
I've also seen the toroid epoxied (or potted in a small box) to a small carrier PCB with pins attached, then soldered to the main PCB.
You can buy pins that clip onto the side of a PCB then solder them into place, so the legs extend down to be mounted to the main PCB.
The Advantest R6142 and R6144 stand their toroid on its side and use one cabletie through two holes on the PCB, so there are a few options.
