Can you power up the circuit? If so, what's the voltage across it?Welcome to EEVBlog.
That's a capacitor. Should be 10V 10uF. If it is not shorted, I doubt there is a problem with it.
It's a tantalum capacitor, 10uF 10V.Keep attention that the white band denotes the positive terminal unlike all other SMD capacitors where the band (usually black) is the negative terminal.
