Author Topic: SMD Tantalum capacitor or SMD diode, resistor...?!  (Read 792 times)
Offline JPBAPTTopic starter
  • Country: pt
« on: December 01, 2022, 11:49:29 am »
Hello everyone.
I have a question about the component in the foto.
Is that a Tantalum cap, or a diode, or maybe a resistor...?!
And the values, how can i no them?
They are almost the same...  |O
Thank you
« Last Edit: December 01, 2022, 12:16:41 pm by JPBAPT »
Online jpanhalt
Re: SMD Tantalum capacitor or SMD diode?
« Reply #1 on: December 01, 2022, 12:05:18 pm »
Can you power up the circuit?  If so, what's the voltage across it?
Welcome to EEVBlog.
  • Country: pt
« Reply #2 on: December 01, 2022, 12:11:40 pm »
Welcome to EEVBlog.
This is from a Car ECU... and i can not power the circuit.
I measure it, and the values are from both sides the ones at the foto.1652438-0
Offline DavidKo
  • Country: cz
Re: SMD Tantalum capacitor or SMD diode, resistor...?!
« Reply #3 on: December 01, 2022, 01:02:41 pm »
Usually there is a lot of ESD protection. It can be TVS diode or something similar.
  • Country: pt
« Reply #4 on: December 01, 2022, 02:48:40 pm »
Thanks friend.
I think you right, its a disse.
But i canto find nowhere watt the reference 10-10 mesma.
I search the NET, no match.
Offline Manul
  • Country: lt
« Reply #5 on: December 01, 2022, 04:01:17 pm »
That's a capacitor. Should be 10V 10uF. If it is not shorted, I doubt there is a problem with it.
The following users thanked this post: JPBAPT
Offline gamalot
  • Correct my English
    • Youtube
« Reply #6 on: December 01, 2022, 04:57:05 pm »
I second.
It's obviously a 10uF/10V tantalum electrolytic capacitor.
https://www.vishay.com/docs/40002/293d.pdf
« Last Edit: December 01, 2022, 05:02:58 pm by gamalot »
  • Country: pt
« Reply #7 on: December 01, 2022, 10:23:37 pm »
Thanks for your help.
I have another question.
I send a photo for 2 caps, can i use the one on the left, the Sanyo 10UF 25V, if the other 10V 10UF is not in good use?
One is tantalum, the other is what we call a "normal" electrolyte cap.
I read a lot about this, and many people do this.
I watch, that sometimes the use of tantalum caps is only because of the space, is that true?
Thantas in advance.
Offline Manul
  • Country: lt
« Reply #8 on: December 01, 2022, 11:19:22 pm »
Electrically speaking most likely everything would be fine, but I would not use it. This is a car ECU, exposed to high vibrations, possibly high temperatures. Don't underestimate that, do a solid repair, grow good habbits.
Offline caius
    • Caius Arcade Repairs & Engineering
« Reply #9 on: December 02, 2022, 06:01:39 pm »
It's a tantalum capacitor, 10uF 10V.Keep attention that the white band denotes the positive terminal unlike all other SMD capacitors where the band (usually black) is the negative terminal.
  • Country: pt
« Reply #10 on: December 02, 2022, 06:07:47 pm »
Yes, true.
I already install it. Its all ok  :-+
