I am using a new 3kW hybrid inverter made by Phocos and I've noticed something unusual.
I have installed in the house the OWL power meter that connects to the main grid entry point with current clamps.
When the battery gets depleted during late afternoon, the inverter switches immediately to grid power.
Then when the loads (400W) connected to the inverter are switched off, the power meter is showing 200W more than
usual. If I measure the power consumption of the inverter directly on the socket which is connected with a socket
mains power meter, it shows around 10 watts, not 200 watts. But it also shows a power factor of 0.05!
When the loads are switched back on the power factor goes up to 0.6
Is this normal?
What is the impact of the extra 200 watts shown on the Owl power meter?
0.05 power factor?
Thanks.
![](https://i.postimg.cc/R0DDbyQ1/Power-Meters.jpg)
