Author Topic: Solder Jumpers using SMD Pads?  (Read 22889 times)
Offline harnonTopic starter
  • Is this thing on?
    • My Personal Website
« on: February 16, 2012, 11:58:11 pm »
Hey guys,
I'm putting together a little board so I can make simple SMD/SOIC prototypes without making a different board every time... one thought I had was to use 0805 resistor pads as either 0805 components or solder jumpers... the spacing between the two pads is around 25 mil / 0.65mm.  What do you guys think, would this work or is the gap too big? Would there be some other issue with this method?
I've attached an image of the board so you can have a look...  its set up to be used with or without a breadboard.
Thanks, Will
Offline Jad.z
Re: Solder Jumpers using SMD Pads?
« Reply #1 on: February 17, 2012, 12:17:26 am »
0.65mm Is fine IMO. Usually I go for 1mm.
If you are going to solder mask this thing keep the area between the pads clear. Trust me you don't want any solder mask in there  ;)
  • Is this thing on?
« Reply #2 on: February 17, 2012, 12:19:22 am »
Thanks - I thought about removing the solder mask, but then not having done too much in the way of SMD soldering yet I wasn't sure what impact that would have if I tried to put an 0805 component on top.  Only one way to find out I suppose!
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: February 17, 2012, 12:48:36 am »
The pad shape and gap makes quite  a difference to how easily links can be made and broken. The optimum shape is a pair of semicircles, as solder blobs like to be circular, but 0805 sized pads with maybe a 25mil gap work OK
Day Job: Mostly LEDs
Offline sacherjj
« Reply #4 on: February 17, 2012, 03:20:14 am »
You also can use normal resistor pads and 0 ohm resistors.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #5 on: February 17, 2012, 04:05:10 am »
It will probably rarely matter, but many zero ohm resistors specs can be as high as 20 mOhm.
  • Is this thing on?
« Reply #6 on: February 17, 2012, 09:04:00 am »
Yep - thats 0 ohms +/- 10% right?  :o  Its a good idea, but the preference would be to "jumper" without any additional components.
I played around a bit with my own patterns - circle inside an arc - but in the end I want to be able to put an 0805 component there if I need it or just solder over if I don't.
I've removed the solder mask from between the pads and I'll see what happens!
Offline amyk
« Reply #7 on: February 17, 2012, 10:47:23 am »
You mean +10%/-0% :D
Using pads shorted together as jumpers is quite frequently seen on laptop motherboards.
Offline ChrisKiwi
« Reply #8 on: February 17, 2012, 11:06:37 am »
You could use 0R 0805 links.  I was working on a board this afternoon that required 2 pads to be linked with solder.  The pads were rectangle 1.27mm x .62mm with a .25mm space between pads.  This scheme worked well, very easy to bridge the gap with solder.  I just tried doing the same with an 0603 footprint (with the solder mask removed between the pads) and it wasn't a very happening thing.
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #9 on: February 17, 2012, 12:23:18 pm »
0 ohms +10%  (x1.10) is still 0 ohms  ;)
Offline robrenz
« Reply #10 on: February 17, 2012, 12:31:07 pm »
data sheet shows 20mOhm maximum for 0 Ohm ;D
http://www.alliedelec.com/images/products/datasheets/bm/DALE/70200976.pdf
Offline mobbarley
« Reply #11 on: February 18, 2012, 12:47:17 am »
I have done exactly that before - except I put a small trace between the pads so that they were connected unless I sliced them with a knife. On boards where there is a solder jumper for setting an option etc, I use a circle split into two pads with ~7 mil gap.
  • Is this thing on?
« Reply #12 on: February 18, 2012, 12:54:24 am »
Actually that's also not a bad idea...
Offline george graves
« Reply #13 on: February 18, 2012, 02:07:27 am »
I think sparkfun has this in their eagle cad library.  Adafruit might have it as well.
