edit: sorry, didn't realize you got it working, only read a few of the first posts in the thread.
Yes, I made it working, and I used it for about 1 year.
My concerns were about the schematic because I didn't know if the schematic is good enough for a simple soldering iron (50W/24V/K- type thermocouple sensor) or if the schematic has wrong components ?
I added the hysterezis to U1A by adding the R24 (1M), R25 (10k), and C33 (100nF) to the circuit. The result was that the oscillation on the pin 1 of LM393 disappeared when I verified with the oscilloscope.
Also by changing the optotriac and triac with a Mos-fet and a mos-fet driver circuit I made the circuit working with 24V/3A SMPS.
I made the above modifications from the internet, they are not original.
