Still working on my rudimentary curve tracer, which I guess should really be called an Analog Signature Analyzer...
Got the basic circuit up and running...A bunch of parts are gonna get swapped out for better parts once I get 'er all figured out. A PIC with a DAC providing the waveform, TL084's amp'ing up the signal w/ variable gain using digital pots, going thru a series source resistance out to the D.U.T., signature signals coming back in, another couple of TL084's, another couple of PICs doing the ADC heavy lifting, feeding back to another PIC doing the control and display of everything.
Working good so far. Still working on the programming for changing frequencies, voltages, etc. Right now, it's a pile of push buttons, but that'll change since the LCD I'm using has a touch panel on it.
Sticking point is the series source resistance between the opamp providing the wave and the D.U.T. Right now, I'm manually switching the source resistor out by hand. Tried finding a digital pot capable of running + and - at both end of the wipers/resistors and be able to carry 500mA at most. No dice. So, it looks like I'm going to be stuck with relays for switching out a variety of source current limiting resistors for the D.U.T.
Solid state relays - Can I assume they don't provide a "zero" resistance across the terminals when activated? Do they pass AC waves down in the millivolt range?
As the title suggests, what specifications in the datasheets should I be looking at when I get to selecting an SSR for this? Or is an SSR just not going to work in this application?
