Author Topic: SPI modes, which is correct?  (Read 687 times)
Offline fabiodlTopic starter
« on: July 11, 2023, 01:27:13 am »
In https://www.allaboutcircuits.com/technical-articles/spi-serial-peripheral-interface/
Mode 3: Clock phase is configured such that data is sampled on the rising edge of the clock pulse and shifted out on the falling edge of the clock pulse.
instead, in https://www.analog.com/en/analog-dialogue/articles/introduction-to-spi-interface.html
SPI Mode 3, CPOL = 1, CPHA = 1: CLK idle state = high, data sampled on the falling edge and shifted on the rising edge.
Which is correct?
Offline ejeffrey
Re: SPI modes, which is correct?
« Reply #1 on: July 11, 2023, 02:29:51 am »
The former is correct.
The CPHA definition  is in terms of "leading" and "trailing" edges where the meaning of leading and following depend on the "idle" state from CPOL.  It's a super confusing and annoying spec.
The following users thanked this post: fabiodl, pdenisowski
Offline ArdWar
  • Country: sc
« Reply #2 on: July 11, 2023, 02:52:15 am »
That AD article is incorrect. Their timing diagram, while technically correct and actually work, don't even help illustrating the difference.
For SPI CPHASE it's usually easier to remember the convention as leading/trailing edge instead of rising/falling edge
« Reply #3 on: July 11, 2023, 11:29:33 pm »
Thank you. It was surprising that a page for beginners is correct and a silicon maker page is wrong.
« Last Edit: July 11, 2023, 11:32:09 pm by fabiodl »
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #4 on: July 12, 2023, 09:55:57 am »
Which is correct?
I actually used this exact same example in my video on SPI
https://youtu.be/0nVNwozXsIc?t=473
(Back up a minute or two for the explanation of CPOL and CPHA before the example)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Free online test and measurement fundamentals courses from Rohde & Schwarz:  https://tinyurl.com/mv7a4vb6
Offline pdenisowski
« Reply #5 on: July 12, 2023, 10:00:58 am »
Yes - I always refer to this as "leading / trailing" or even "first / second" edge to avoid confusion.
« Last Edit: July 12, 2023, 10:06:47 am by pdenisowski »
