Author Topic: Step Down Converter power consumption  (Read 2732 times)
Offline Mark IVTopic starter
« on: February 02, 2016, 08:28:09 pm »
Hi All!
How can i calculate the power consumption of a buck converter like this one: http://www.ti.com/lit/ds/slvsac3d/slvsac3d.pdf? Do i need only to consider the quiescent current or I need to take care of other params?   :-BROKE :-BROKE
Offline mikerj
Re: Step Down Converter power consumption
« Reply #1 on: February 02, 2016, 09:10:52 pm »
The power into the regulator will depend on the power into the load and the efficiency of the device.  e.g. if it was only 50% efficient, you'd have to put twice as much power in as you got out.
« Reply #2 on: February 03, 2016, 09:23:19 am »
So, an example:
I use 2xAA batterries with 2500 mAh and the buck converter with 50% efficiency and 100 mA quiescent current. If the load takes 2400 mA, the battery life should be 0.5 hour, correct?
Offline mikerj
« Reply #3 on: February 03, 2016, 10:38:08 am »
So, an example:
A switching regulator is a constant power device i.e. output power = input power * efficiency.  You are talking in terms of only current, so without knowing the voltages of the supply and the load there isn't enough information to answer your question.
The quiescent current of a switching regulator is taken into account in the efficiency calculations, which is why efficiency falls as the load current falls to low values.
e.g. if your batteries are wired in series and give 3v, and your load voltage is 2v and the load draws 100mA
Load power = 2*0.1 = 0.2 Watts
Source power = 0.2/50% (i.e. 50% efficiency at the given load current) = 0.4 Watts
Source current = 0.4/3 = 0.133 Amps
Battery life = 2500/133 = 18.8 hours.
In practice battery life isn't as easy as that to calculate, since the capacity of the battery varies according to how much current to draw from it, and also the voltage at which your system stop working.
« Reply #4 on: February 03, 2016, 11:13:18 am »
Thanks!
Yes, and also the voltage fo the batteries goes down over time...It seems a good problem to solve.
