Good Morning Eassssse, First of all, welcome to the Forum. I'm curious what would lead you to an electronics forum to seek advice for a plumbing problem
? If you wanted to find logical thinking minds, you did make a good choice, as you have, what I consider, some of the most logical, educated, and helpful minds of any forum on the internet. A lot of good ideas have been given to you, but I believe you need to provide more information, in order to help narrow the problem, like the type of construction you have, and where the water supply pipe enters the building, and if the meter is remote from the building. I especially like the idea of draining the entire system and filling it with compressed air. I'm not a plumbing expert, but being a homeowner for over 50 years, and a DIYer, I've experienced quite a few plumbing problems, but the one that most closely resembles yours was a similar minute leak that eventually led me to a toilet flush valve. Luckily, I had valves that would isolate various parts of my home. Also, shut off the water going into your hot water tank, which should prove or eliminate the hot water piping. Good luck, and be sure and post your eventual solution, and the method you used to track it down.
