Author Topic: Help with the bridge rectifier connection - paralel or series  (Read 11763 times)
Offline txescientistTopic starter
  • Country: cs
Which is the better way to connect bridge rectifier to get one sec winding voltage and two sec windings in series? Left or right configuration on the attached schematic? Transformer has two separate secondary winding, not center tapped.
Thanks!
Offline Zero999
  • 0999
Re: Help with the bridge rectifier connection - paralel or series
« Reply #1 on: August 04, 2017, 11:13:05 am »
Neither. Use a single bridge rectifier and the two transformer windings in series, which is equivalent to a centre tap.
Offline anishkgt
  • Country: qa
    • George Hobby
« Reply #2 on: August 04, 2017, 11:13:16 am »
You would not need two bridge rectifiers here. Just one would be enough but you'd just one output with higher current in parallel or higher voltage in series.
Sent from my iPhone using Tapatalk
Offline Zero999
  • 0999
« Reply #3 on: August 04, 2017, 11:24:17 am »
Here's the image I was looking for. If the windings are in series, the part where they join is equivalent to the centre tap. As you don't need regulation, you're using a 9V transformer and no regulators, so ignore that part.
Offline digsys
    • DIGSYS
« Reply #4 on: August 04, 2017, 11:54:43 am »
Either is technically ok, but I'd go for #2. It's cleaner. Just note the the bottom 12V bridge will carry BOTH currents.
The CT option suggested has a -12V, or it puts the GND in a bad place. The OP wanted +12V and +24V
  • Country: cs
« Reply #5 on: August 04, 2017, 11:57:20 am »
Thank you for the reply. I need full bridge rectification, Vout ~= Vac*1.41
I am using this transformer with two secondaries because I need 20-24V for the charger, and 9V and 5V for control circuitry (OPAMP, PIC micro...) and don't want to burden linear regulator with higher voltage tap. Also, I have another smaller transformer for the -9V rail.
Offline Ian.M
« Reply #6 on: August 04, 2017, 12:14:47 pm »
The single bridge + series pair of secondaries with center tap is only an option if the secondaries are well matched both in voltage and DC resistance.   If not, its best to connect each secondary direct to the AC terminals of its own bridge rectifier and *ABSOLUTELY* *NOWHERE* *ELSE*, then 'stack' the outputs of the bridge rectifiers.
For the single bridge circuit, the usual configuration is to ground the center tap for equal + and - rails out of the bridge, but if you ground the - side of its output, the center tap of the secondary will supply half the DC voltage of its + terminal.
Offline Zero999
  • 0999
« Reply #7 on: August 04, 2017, 01:14:10 pm »
The ground connection is arbitrary. All voltages are relative.  :palm:
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« Reply #8 on: August 04, 2017, 01:57:47 pm »
Thanks!
GAH! neither, yuk!
Hero's first solution is what I would do, then regulate down the supply voltage for the electronics. Providing th electronics weren't pulling a large amount of current the reg would manage. Or you could do this?
but if your charge needs to be referenced to the electronics, then you'll need to isolate the charger -ve from the electronics 0V - we need more context in what your trying to do?
« Last Edit: August 04, 2017, 01:59:35 pm by tron9000 »
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline mariush
« Reply #9 on: August 04, 2017, 03:14:28 pm »
If you don't care about efficiency, you could just make up a capacitive power supply directly from 24v AC or whatever you have on the output of the transformer.
See http://ww1.microchip.com/downloads/en/AppNotes/00954A.pdf , first 2-3 pages.
Just change 110-120v AC to 24v AC and use a ~9-10v zener diode to get your 9v for opamps and then you can use 5v ldo powered from 9v.
You can probably omit R1 from circuit and your X2 capacitor may be rated for lower voltage, just enough to handle transformer's output voltage + maybe around 20-30%
  • Country: cs
« Reply #10 on: August 04, 2017, 03:37:54 pm »
Sorry I didn't explained what I am making in the first place. I am building variable DC load to test SLA batteries with an integrated charger. All parameters as voltage, current, temperature are sent to PC via USB.
So, charger circuit is ground referenced with the rest of the circuitry. Need a full bridge rectifier circuit. Currents are small, 500mA for charging (20-24V rail) and maybe 100mA for the PIC and the rest...
Found this http://www.hammondmfg.com/pdf/5c007.pdf but it is just for common configurations...
Offline drussell
  • Hardcore Geek
« Reply #11 on: August 04, 2017, 03:57:21 pm »
That is certainly the normal way of doing it and I would think it is the simplest....
Like Hero999 says, where you connect the center tap and your "ground" are arbitrary, it just depends on whether you want two "stacked" voltages (positive or negative) or symmetrical +/- around your 0v point.
Offline David Hess
  • DavidH
« Reply #12 on: August 04, 2017, 04:48:34 pm »
If Hero999 had not posted that solution then I would have.
Offline Zero999
  • 0999
« Reply #13 on: August 04, 2017, 06:33:06 pm »
There's nothing special about me. I was just the first person to see the thread.
How much current does the -9V supply need to provide? Do you really need another transformer? Can't you use a voltage doubler?
I know that gives -12V but that might not matter, as you could use a regulator (LM78L09) or zener diode to get 9V.
« Last Edit: August 04, 2017, 07:21:28 pm by Hero999 »
The following users thanked this post: txescientist
  • Country: cs
« Reply #14 on: August 04, 2017, 07:48:25 pm »
That could be done, it is a good way to get negative supply, seen it in many power supply designs that allows voltage to be set to 0V. I will use another transformer just to shift some load of the first one. Problem is that I already have the case for the project and the main transformer is limited by the case size. But, with two transformers, I can power up all the circuitry (charger, laod, fans etc.).
Thank you all for the fast and good suggestions and solutions  :-+. Should have used switching PSU, but that is an other story...
