Thank you for your answers.
Depending on the current the pump needs you have to select the needed MOSFET.
In fact, the pump (
https://whadda.com/product/mini-peristaltic-pump-6-v-vma447/) doesn't seem to have a "real" datasheet. I could only know that it is "
6V and 5W". I did the calculations P = V I and that gave me: current = 833.33 mA.
Does this mean that this pump requires 833 mA to function correctly?For small currents a 2N7000 can be used.
I looked at the datasheet for the 2N7000, and I am not sure what to look at for MOSFETs. I saw that the "maximum drain current" is 200.
Does that mean that it can at most give out 200 mA? If so I imagine it would be insufficient to power the pump. And if not, what is the value I should be looking at to know if it can output that amount of current?
As a side note:This is what confuses me about transistors as switches. It seems like they don't really act as switches if I understood correctly. They act as switches only to some extent, in that they let current flow or not flow. But they change/modify/put a limit on (?) the current flowing out. Instead of just being like a
physical switch that opens or closes a circuit without affecting the current, i.e. 2 A comes out of the batteries, 2 A will also come out of the switch to reach the pump. In the case of the
transistor as a switch it seems like if 2 A come out of the batteries, only 200 mA come out of the switch, and 1.8 A seems to be
lost in some sense. (Sorry if this doesn't make sense I can clarify if needed)
Thanks again
