Author Topic: Toggle relay when press power button on remote control?  (Read 948 times)
Offline YurkshireLadTopic starter
« on: January 30, 2022, 08:12:15 pm »
I have 5V relay board like the one pictured below. It's controlled using an IR receiver and the remote control.
The relay switches when I press the power button on the remote, but it resets as soon as I let go of the button. I tried programming the board as per the instructions (hold down the button on the board for 5s, release and press the button to turn on etc). But that didn't work. I want to to switch the relay on when I press the button, and then switch it off again when I press the button a second time. Does anyone familiar with this type of board know how to achieve this?
https://universalsolder.b-cdn.net/wp-content/uploads/2021/01/5071_14e323fa-c0c5-464f-93ac-04c998c9b1970.jpg
Thanks
Re: Toggle relay when press power button on remote control?
« Reply #1 on: January 30, 2022, 08:39:56 pm »
Never mind. Face palm moment - I had to remove the jumper to change into toggle mode.  |O :-DD
Offline rpiloverbd
  • Country: bd
« Reply #2 on: February 03, 2022, 03:15:26 pm »
Good to know that you found the solution.
