Author Topic: Tool to open snap-in cases?  (Read 4284 times)
Offline AxtmanTopic starter
« on: February 22, 2014, 05:47:21 pm »
Where can I buy the tool that Dave uses to open up the snap-in cases?  It looks like a butter knife with the end ground flat.
Thanks!
Offline G7PSK
  • It is hot until proved not.
Re: Tool to open snap-in cases?
« Reply #1 on: February 22, 2014, 05:51:44 pm »
Ebay. look for spudgers.
« Reply #2 on: February 22, 2014, 05:57:21 pm »
"Spudger"?!  Did you just make that word up?  :)
Offline GreyWoolfe
  • NW0LF
« Reply #3 on: February 22, 2014, 06:31:18 pm »
No, it's real.  I just checked eBay and they do exist :-DD
Offline zapta
« Reply #4 on: February 22, 2014, 07:12:42 pm »
Not only that he made that word up, he created a Wikipedia entry for it  ;-)
http://en.wikipedia.org/wiki/Spudger
I got this one from DigiKey recently. Don't think it is strong enough to pry cases. It is like the pointing tool Dave used in some videos.
http://multimedia.3m.com/mws/mediawebserver?66666UuZjcFSLXTtmXf6mxMVEVuQEcuZgVs6EVs6E666666--
There are special kits with case prying tools. For example this one http://www.amazon.com/Tools-Repair-Open-apple-iphone/dp/B001LKZNMI
Offline sacherjj
« Reply #5 on: February 22, 2014, 07:53:47 pm »
Plastic if good to not scar plastic.  I like the thin steel iSesamo to get into most things.
Offline KJDS
    • my website holding page
« Reply #6 on: February 23, 2014, 11:07:28 am »
They don't replace a hefty screwdriver for heavy duty destruction.
Pah! use an axe, guaranteed to gain entry to even the most solid plastic case. :)
Offline babysitter
  • pushing silicon at work
« Reply #7 on: February 23, 2014, 11:11:56 am »
I can recommend guitar picks, even to hold snap-feet open after prying so they don't reconnect when you go on to the next one...
I'm not a feature, I'm a bug! ARC DG3HDA
Offline apelly
  • Probe
« Reply #8 on: February 23, 2014, 11:47:40 am »
I second plectrums. They're tough and cheap and last forever. I recommend thinning one corner to get into really tight spots.
Offline notsob
« Reply #9 on: February 23, 2014, 11:49:22 am »
have a look at http://www.ifixit.com/Store/Tools
under the prying and opening section
Offline G7PSK
« Reply #10 on: February 23, 2014, 03:38:27 pm »
You can never have enough spudgers and podgers lying around in various sizes.Along with assorted pry bars crow bars etc. The best tool I have found for glued or welded cases is a pneumatic chisel, just about nothing fails to give to one of these.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #11 on: February 23, 2014, 03:52:21 pm »
My amazon review of the iSesamo tool
The tool is excellent material and the shape and thinned tip are excellent. But the edges are left as stamped and have your normal edge roughness that could scratch cases. A few minutes of deburring and polishing the edges yourself makes it the perfect tool.
My amazon review of iFixit Pro Tech Toolkit that contained metal and plastic spudgers
Everything except the metal spudgers and pry tools were reasonable guality. The tweezers I received were actually above average. The metal spudgers/pry tools were good quality steel with a good temper but the shape and grind quality were horrible. Fortunately I can grind these to shape myself. Don't buy this kit expecting any of the metal spudgers/pry tools to be useable as received.
