First post here. I am retired welding engineer who never had the time to become knowledgeable about electronics. Fixing things has always been a passion. Maintained my own autos, but the circuits there were usually easy. Wired two houses, but nothing fancy there. At 73, I shouldn’t play tennis, ski, climb ladders, or ride dirt bikes anymore, but bench work, why not? Lots of great electronics content on youtube, and right here on EEVblog. So I am setting up a bench, consuming a ton of new information, and having fun doing so.
My wife loves her Pfaff 1473 sewing machine, 1988 YOB( Pfaff, not my wife). The 1400 series (1983- 1995) were Pfaff's first computerized machines. This one has two stepper motors to move the needle and fabric in ways impossible with mechanical cams. The 1400 series machines are sought after because they have an integral dual feed and were extremely well built in Germany. Unfortunately, Pfaff has been sold to private equity multiple times and factory support ended decades ago. Nonetheless the 1400 series are worth saving and repairing. The main PCB is often cited as the reason they cannot be fixed. Yet there are documented cases of these boards being repaired on this blog and on other forums around the world. So I want to contribute.
Recently our 1473 stopped working although it did turn on. Taking these machines apart is a challenge of its own. Pfaff hid screws of various types including M3 pozidriv. But I was not deterred and took out the main pcb to look for trouble (shown in the attached pic). To my beginner mind the main pcb looks modern, somewhat understandable, and fixable. I measured the ESR of all the capacitors and they were okay. I did remove and replace the big yellow one, it measured 0.061 ohms ESR, 2630 uF. (Spec 0.20ohms/2200uF). I had trouble getting solder out of the via so I left the others alone.
There were no obvious problems on the main PCB so I decided to look at the motor. The motor is also difficult to get to with screws accessed from top, front, and bottom. I had thought that with all the digital complexity on the main PCB that the main motor would be a DC Servo type. But when I final got it out, I recognized it as a series-wound universal motor with no positional feedback wheel. I wanted to test the motor but was confused by the components on the small PCB attached to it. I found two crude schematics on the internet that both indicated the Pfaff motor PCB used two triacs. I could not find any similar circuit designs that used multiple triacs on the internet, and indeed several sources said triacs should not be used in series or parallel.
I don’t like working on things I don’t understand, so I carefully sketched up the traces and component locations, and drew the attached pdf schematic in KiCad. After replacing the badly worn-out brushes and re-installing the motor the machine seems to be working fine again.
Since this forum is “a place to ask questions”, I have a few:
1. It seems that after successfully operating for many decades these machines prove that Triacs can be wired in series. What did Pfaff do that worked so well?
2. The motor control board is very small and simple in design. There is no heat sinking of the Triacs either. Are the Triacs used because of the small space?
3. I don’t have a scope so I could not see what the output looks like on the gates of the Triacs from the main PCB. Can anyone suggest what that might be? The connecting wire size is very small diameter.
Thanks for reading this.
