Hi all,
Long time lurker, first time poster. I've been flirting with the idea of building a little hobby electronics lab for a while now and I've finally got the space for it after moving into a new place. What spurred me to finally register and post on here is purchasing my first bench supply. I got what seemed (at the time) like a good deal- $70 (+ $30 shipping) for a LIP 40V/1.5A dual linear tracking power supply (LIP Elec. Eng LTD Model LPS-401D).
So it arrived today. I got it hooked up and turned it on. Channel "B" works as it should... channel "A" is a different story. It immediately current limits, even with no load. Here is a video of me doing the unthinkable... turning it on before taking it apart.
https://youtu.be/mmNxnKIk9w4What I'm looking to you, wonderful EEVbloggers, for is for a bit of assistance/advice on troubleshooting/fixing this power supply. I'm no EE, but I've designed and built a few synthesizer modules over the years, so I'm not a complete newbie. So let me clue you into what I've found out so far...
After powering up the unit, it starts up in standby, I set the voltage to 18V and the current to 1.0A. Turning it off of standby- channel "A" goes into current limit mode immediately. The terminals are outputting SOME voltage- on the order of 32mV when current limiting at 1A. Adjusting the current up or down adjusts the voltage. So the current/voltage adjustments are working, just not properly. The (+) & (-) terminals (on channel "A") read approx. 3Ω. Open from GND to either terminal. So there is a short between (+) & (-). The terminals on the rear are not shorted. (FYI, Channel "B" reads about 3kΩ from (+) to (-) terminals & open to from either terminals to GND- so this is, I'm assuming, the proper reading).
I opened the unit up and everything looks good. No black marks, no bulging caps, no burned ICs. Nothing obvious. The unit is laid out very well and almost everything on the power supply board is socketed. Diodes, resistors- I have never seen this before. Hopefully will make it easier to fix. Below are some photos of the unit and boards.
Tomorrow, I'm going to start actual troubleshooting, testing the capacitors first (with in-circuit ESR tester), then the diodes, then the pass-transistors.
If you guys have ever run into a similar issue or know the ins/outs of linear power supplies, then I'm all ears. I searched FAR and WIDE for any info on this unit. Besides a Reddit post and a couple of eBay listings- there isn't anything that I could find (about the company or about the model). Without a schematic (or even a manual) it's going to be on the _difficult_ side for me. Any help would be greatly appreciated.
-Ben
Unit Photos:
Front of Unit -
https://photos.app.goo.gl/RYPK2PMaNUyUiLgQ9Rear of Unit -
https://photos.app.goo.gl/ApHbUWGhwzdsvKfs9Top-Down of Unit with Cover Off -
https://photos.app.goo.gl/uykMQBzW32nLdxck9Top Board (Linear Power Supply Board) -
https://photos.app.goo.gl/F8QBrqUo1BXg6qgq8Bottom Board (Controller/Logic Board) -
https://photos.app.goo.gl/srUpnaSEUQCfYZYx9
