Author Topic: troubleshooting a cash drawer solenoid - really... justification for a SCOPE!!!  (Read 7142 times)
0 Members and 11 Guests are viewing this topic.
Offline rutgradTopic starter
Hello, I am a long time "lurker" in the forums and finally have an opportunity to put some of the knowledge I have gained from the forum and videos to work. I just ordered my DSO1054Z for this project.  Finally have a reason and purpose to acquire my own scope ;D
So here is my challenge...  a point of sale (POS) system uses an Epson receipt printer (TM-T88IV).  The printer has an RJ11 cash drawer trigger port which sends a 24V pulse to activate a solenoid which mechanically opens a cash drawer.  I have tried multiple cash drawers and multiple cables and cash drawer operation is not triggering.  So I figured I would create a breakout cable to test to see whether I am getting any signal, bad signal or incorrect voltage, but I don't want to blow up my new scope when it arrives.  I also I want to make sure my test protocols are correct.
The RJ11 port is configured as follows:  (I have also included a detailed pdf of the circuit and details of its operation)
Pin1:  Frame GND
Pin2: Drawer Kick-out signal1 (Output)
Pin3 Drawer Closed / open signal (input) "provides drawer state"
Pin4: +24V
Pin5: Drawer Kickout drive signal 2 (Output) "for second cash drawer if required"
Pin6: Signal GND
I presume I should probe pin 4 to make sure it has +24V.  Then probe pin Pin 2 looking for 24V when open signal is sent.
signal should last according to the following calculation found in teh atacehd PDF (2mS x t1)  where t1 is set to 100mS in our software
I assume i have to set the scope to trigger so the  "capture" occurs.  not sure how to do that but I will certainly try and RTFM when it arrives.  (if I can avoid the urge to probe!)
Sound about right? Any advice would be greatly appreciated.
« Last Edit: July 26, 2016, 04:42:21 pm by rutgrad »
Offline pyroesp
    • Nicolas Electronics
All (?) scopes come with a little square wave gen of 1kHz. Connect your probe to it and have a play with that (triggering correctly , single shot, continuous, etc) just to have a feel for the scope. Also, there's a tutorial here on how to use a scope, might be interesting to read:
Oscilloscope training class (long)
Also, set your probe to x10 and configure the channel to using a x10 probe (if it's one of those x1 - x10 probes).
I don't see the pdf on your post ?
Down-right, there's the 1kHz sq. wave on the rigol DS1052E.
« Last Edit: July 25, 2016, 04:57:10 pm by pyroesp »
The following users thanked this post: rutgrad
Offline CJay
Nice reason to buy a 'scope but while you're at it, order some capacitors for the TM88 power supply, they go leaky nd cause exactly that problem.
Thanks for your replies.  FYI...  I modified my original post to add the missing document.  Apparently it was just a tad too large first time.
Offline SL4P
  • There's more value if you figure it out yourself!
I think you're working under an incorrect assumption.
The cash drawer does NOT output a 24V pulse.
On page 1 of the PDF manual, it clearly indicates an open collector arrangement, and a 24V supply for the drawer solenoid.
Put the high side side of the solenoid to the 24V rail, and (assuming the solenoid is within the open-collector rating), put the low side of the solenoid on the drawer output pin.
Remember to put a diode across the solenoid to catch EMF kickback.
Don't ask a question if you aren't willing to listen to the answer.
Offline PA4TIM
And then you can use your scope to test the psu for ripple to check if the caps are OK  ;)
