Because it's not so much a "detector" switch than just a switch.ie: In the old days, they simply used these contacts to turn off the speakers (left and right) when you plugged the headphones in.
Quote from: Kim Christensen on May 11, 2024, 02:11:16 amBecause it's not so much a "detector" switch than just a switch.ie: In the old days, they simply used these contacts to turn off the speakers (left and right) when you plugged the headphones in.Your diagram is incorrect. Convention is for the tip to be left audio, not right.
