Author Topic: Two dumb questions about opamp lore and a solar pump controller circuit I found.  (Read 7072 times)
Offline Ed.KloonkTopic starter
  • Cat video aficionado
Hi.
Here is a schematic I found on Google images with no further detail. Most of it I can follow, but there are two things I don't quite understand...
1) What is the purpose of the diode(if it is not just for polarity protection) and the 10ohm resistor near the 12v input?
2) Why would you tie one of the op-amp inputs to the other unused op-amp? Wouldn't be more sensible to tie that input (pin 5) to ground since the pin next to it (pin 6) is grounded and pin four(gnd) is not so far away either?
iratus parum formica
Offline Psi
Found some more info on that circuit here, might be useful
http://www.siliconchip.com.au/cms/A_30610/article.html
The diode maybe there to protect against back emf from the motor.
« Last Edit: May 08, 2011, 10:04:49 am by Psi »
Ah. Thanks for that.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
look like not.
Offline Psi
look like not.
It would block reverse polarity produced from any back emf when the supply is cut. But yeah, its not located across the motor like one might expect.
« Last Edit: May 08, 2011, 01:02:38 pm by Psi »
Offline bilko
I would say it is used to decouple the control circuit power supply from the motor power supply.
The 10 ohm resistor and reservoir capacitor provide a smoothed voltage to the LM393 comparator circuit. The diode prevents the control voltage draining back when the motor is switched on. Without the diode, the control circuit would switch off when the motor is switched on, causing the circuit to oscillate (depending on the size of the motor)
« Last Edit: May 08, 2011, 01:44:02 pm by yachtronics »
Offline Psi
yeeh, that makes sense
Offline mikeselectricstuff
    • Mike's Electric Stuff
LM393 is a comparator, not an opamp. tying comparator inputs together may cause oscillation, so they use inputs that will always be significantly different.
BTW the reason the diode is where it is is to avoid it needing to be big enough to carry the motor current. If connected backwards, the MOSFET's body diode would turn on, & the motor would run (backwards), but the diode protects the rest of the circuit.
The 10R provides some filtering, and may also be intended to act as a fuse, in case of a fault with the control circuit drawing excessive power.
Day Job: Mostly LEDs
Offline scrat
I can't get this. How could the MOSFET's gate, or the high value resistors conduct the DC motor's current? With reversed DC input the current won't need to pass through the series diode, it will simply go on the MOSFET's body diode, as you mention.
I agree with yachtronics.
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
They don't - maybe you misunderstood my comment - I was mentioning the reason why the reverse-polarity diode wasn't at the DC input to the whole circuit, which might be the more obvious place to someone reading a 'beginners' forum.
Wow. Thanks for all the replies. Fantastic information. I learned something several things today.
Offline scrat
@mike: I see now... If the motor running reversed isn't a problem, you don't need protection there, of course.
