I'm running out of solder, and probably going to order more in the next month or two. I've been using lead-free solder, MG Chemicals 4901-227G, labeled SN99 and made from 99.3% tin and 0.7% Cu. The wire size is 0.032 inches, and it's labeled No Clean, but I've been cleaning the flux off the boards anyway because they look better when cleaned.
I would like to try SN100C solder, with a slightly different composition. I like the .032 diameter so I am going to stick with that. On the web site I am looking at, I have three choices for the flux core of the solder wire. The manufacturer is AIM, and the part numbers are 14220, 14168, and 13247. FastCore 2.5%, GlowCore 2.5%, and WS482 3%. FastCore and GlowCore are described as no-clean, and FastCore is described as having excellent thermal transfer capabilities. WS482 is the water-soluble one, halide-free. Both GlowCore and WS482 are described as "highly active."
I am hand-soldering using a soldering station that has a built-in smoke absorber, but the smoke absorber function quit working because I think it got all clogged up with flux residues. I may attempt to fix that, but it might stop working again, so the health effects of breathing solder fumes are a consideration for choice of flux. Another consideration is the fact that I intend to clean the flux off even if it is labeled no clean, so I would like something easy to clean. I've been using isopropyl alcohol, ethyl alcohol, or acetone for cleaning the flux off the boards.
Any thoughts on which flux I should choose? I think I once read that the water-soluble ones have bad fumes.
