Ultra sound in your usual air u breath at 14psi, is about 1 db/m absorption, for 50khz, so I read.
I have a hypothesis, but I cant get any answers on the internet->
If I compress the air, does this raise the frequency/ drop the absorption - whilst keeping the velocity of the sound the same?
If I lower the temperature its true, the sound stops absorbing when the air is cold, but that increases the velocity, is the same true for when the pressure is risen high enough - but the velocity stays the same?
